The fan noise from my Kitchen Aid Range, model no. kgsk901sss01 has become increasingly loud. It has always been annoying from day one but now is to the point that being in the kitchen while the oven is on is horrible. The noise, which I am assuming is a fan, immediately starts when the oven is started and runs for quite awhile after the oven is turned off. From what I have read, this is more than likely the blower, your part part no. AP3851090. Before purchasing the part, I want to be sure this is the issue and inquire as to how difficult it is to replace myself. I am pretty handy with tools and not too intimidated with stuff like this. I would rather not request a service call as I have already spent enough in repairs on this range so am hoping I can do this myself. Thanks so much for your help! :)
Does sound like a fan problem. I usually do not mess with gas units but this is closer to just an electrical/mechanical problem. I think the following will be a close match to your unit. Whirlpool KAC-42 KA M-Line Slide-In Freestanding Gas Range Service Manual - ApplianceDigest.comYou may have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer. You could pull the fan and then hook it up yo a line cord to confirm that it is toast. Remember to unplug the unit when working on it. You would be surprised how many folks forget this and end up having to replace control boards. |
THIS FORUM IS DEAD!!!!!!! |
Thanks so much Denman for the reply to my post and info. I registered on that site to get the manual you suggest however get a message " [#10869] You do not have access to this section of the site " when I try and access the link. Thanks again for your help. :)
Not sure what is happening but did you register (join) the site?
I just went to the site and had no problem. |
Thanks Denman! I was able to get access to the site. :)
Originally Posted by: KeithWC Thanks Denman! I was able to get access to the site. :) Hi Keith, I'm new to this site but am having the same problem with my JennAir ww30430P oven. Did a new fan do the trick for you?
