frmhere2
#1 Posted : Thursday, October 25, 2007 4:12:01 AM(UTC)
frmhere2
my side by side fridge is acting strange.
1. the fridge does not get cold.
2. the freezer works.
3. also water is leaking from bottom of fridge.
yesterday i changed the auto defrost system. the freezer works but the motor continuously runs and the blower/fan (which blows the air from freezer to the fridge) is not operating at all. also before all this happened, the fridge leaked water from under and i turned the water off from its power source. help.
:D
it has now been 24 hours,
could it be that it takes time for fridge time to get cold. right now 24 hrs later, the fridge is getting cold. i have not seen the blower work, where the freezer air is forced through upper vents. i put pop in it last night and now it is cold but not cold cold.
richappy
#2 Posted : Thursday, October 25, 2007 2:55:13 PM(UTC)
richappy
Pull the back freezer panel out and check evaporator fan.If voltage to it, but it fails to run, you will need to order one by clicking on your model # above.
frmhere2
#3 Posted : Friday, October 26, 2007 3:45:55 AM(UTC)
frmhere2
what about the water leaking from under the fridge
freezer cold,fridge not cold enough (Refrigerator & Freezer Repair)
by BSTrue 11/18/2018 2:40:04 AM(UTC)
Fridge Not cold enough (Refrigerator & Freezer Repair)
by water101 1/10/2018 8:28:55 PM(UTC)
Kenmore fridge not cold enough (Refrigerator & Freezer Repair)
by benbenherenow 4/9/2015 1:26:32 PM(UTC)
Fridge not cold. Freezer ok (Refrigerator & Freezer Repair)
by PURCHIARONI@ATT.NET 3/7/2015 12:27:16 PM(UTC)
Freezer fine, Fridge not cold (Refrigerator & Freezer Repair)
by WWats004 1/9/2015 7:44:09 AM(UTC)
Freezer & Fridge not cold - coils cold, evap fan works but not running (Refrigerator & Freezer Repair)
by bootpdx 1/6/2015 9:51:56 AM(UTC)
by agdodge4x4 8/3/2014 7:04:28 AM(UTC)
Kenmore freezer cold, fridge not cold (Refrigerator & Freezer Repair)
by bc. canuck 7/8/2014 9:06:32 AM(UTC)
SxS fridge not cold & shuts off (Refrigerator & Freezer Repair)
by 77bravo 6/3/2014 1:03:00 PM(UTC)
Freezer frosting over, fridge not cold (Refrigerator & Freezer Repair)
by spowel007 4/5/2014 2:20:16 PM(UTC)
Freezer And Fridge Not Cold Enough - GE Profile Arctica (Refrigerator & Freezer Repair)
by lakeober 7/14/2013 8:43:21 PM(UTC)
Frigidaire Freezer working, Fridge not cold (Refrigerator & Freezer Repair)
by jalill 11/27/2012 4:40:19 AM(UTC)
Freezer vents covered with ice/ fridge not cold (Refrigerator & Freezer Repair)
by amytorp 11/1/2012 1:16:35 PM(UTC)
frezzer back freezing up- fridge not cold (Refrigerator & Freezer Repair)
by murphy7513 10/4/2012 10:09:15 AM(UTC)
kenmore - Freezer and Fridge not cold (Refrigerator & Freezer Repair)
by srinia 8/17/2012 7:00:24 AM(UTC)
