Mack Norton
#1 Posted : Tuesday, October 23, 2007 8:28:05 PM(UTC)
Mack Norton
My washer goes completely through the cycles.However the spin cycles are slugish and the clothes are not dry enough to put into the dryer. What is the trouble with my washer.MN:confused
richappy
#2 Posted : Wednesday, October 24, 2007 2:54:45 AM(UTC)
richappy
Pull away front panel and remove water pump and motor. Turn tranny coupler clockwise till tub starts turning.If it's very hard to turn with two fingers, you have dragging brake shoes or something stuck in the tub.
Shine a bright lite in the spin basket and look for something. If nothing, you probably have dragging brake shoes.
Remove agitator and loosen drive block nut on top of the spin basket, pound on the nut and pull up on the spin basket,basket should break loose.
Remove tranny and pry down brake shoes and spin tube. Remove spring and C clips and brake shoes and order new ones.
If not available, you can fix your brake shoes by grinding down the pads 1/4 inch or more and re-install.
Wet Spin Cycle (Washer Repair)
by Dan312 12/13/2011 8:21:15 AM(UTC)
clothes wet spin cycle very noisy (Washer Repair)
by turtlebug 7/26/2009 5:56:12 AM(UTC)
