MW runs fine light comes on turntable rotates timer works but it just don't heat..
Remove the wires from the high voltage transformer primary winding and check for 120VAC between them while the control calls for heat and the door is closed. If there is 120VAC then the magnetron id bad. If there is no 120VAc then the control board has to be replaced. Here are the break down diagrams for the GE microwave Model JES1144WY03Gene.
