Roho
#1 Posted : Tuesday, January 6, 2009 7:34:46 PM(UTC)
Roho
My GE Potscrubber Dishwasher will not cycle through the wash cycles.
-The knob is not stuck and the washer will cycle through if you turn manually.
-I checked the timer connections all attached and no corrosion.
-I do not have meter so can not check
-I checked the water and it appears hot
-The washer will cycle through the Heated Dry cycle and dries appropriately?
Can it be anything other than the timer? I have located timer on the internet for about $75. Washer is old but I do not want to replace if I can fix for under $100.
Any advice would be greatly appreciated.
#2 Posted : Thursday, January 8, 2009 9:56:14 AM(UTC)
Roho,
Most likely the problem is a bad timer and you can buy it from Appliance Parts Pros for $68.45
- The part number for the timer is AP2039702
Here are the break down diagrams for GE dishwasher Model GSD3610Z05AA
Roho
#3 Posted : Sunday, January 11, 2009 10:07:25 AM(UTC)
Roho
Roho,
Thanks for the response and links Gene. I will let you know.
Roho
#4 Posted : Saturday, January 17, 2009 9:52:10 AM(UTC)
Roho
Works great. Thanks again
#5 Posted : Saturday, January 17, 2009 3:34:22 PM(UTC)
