Mais Oui
#1 Posted : Thursday, March 31, 2011 3:40:10 PM(UTC)
Mais Oui
There is nothing displayed on the touch pad of my built-in electric double oven. Neither the top nor the bottom oven will work. There is an audible beep when I touch the pad's buttons, but no time or temperature display and neither oven works.
Both inside bulbs light when I open the oven doors, and the timer still works (beeps after 1 minute checked on my watch); although, you can't see the set time or countdown on the display.
I've checked circuit breakers, switched power off and (after a few minutes) on to try a hard boot of the computerized parts, cleaned small amount of dust from the components behind the display panel (including the control board), and unseated and re-seated all connections I could reach without totally pulling the oven out of the wall. Nothing changes. :( Installed by builder when the house was built, so no warranty. Please help.
Joe / APP Team
#2 Posted : Friday, April 1, 2011 8:35:47 AM(UTC)
Joe / APP Team
Mais,
Sounds like your control transformer or fuse has failed.
Part number: AP3968801
Part number: AP3110028
If you have a multi meter, you could check for the voltages at the main control board,
At the P16 connector :
Insert the meter probes in the wire insertion side , or lift the connector up slightly.
Red wire Pin #5 and Red wire pin#7 should read 120 VAC across the 2 pins.
No voltage would indicate an open thermal fuse.
Blue wire Pin#2 and Blue wire Pin#3 you should read at least 20 VAC across the 2 pins.
No voltage indicates and bad transformer.
If all the checks here are correct, you'd have a bad control board.
Part number: AP3595759
You also want to check connector P18 pin#3Black wire for 120 VAC, to confirm you do have 120 VAC, on the L1 power supply to the oven.
Good Luck,
Mais Oui
#3 Posted : Monday, April 4, 2011 2:16:18 PM(UTC)
Mais Oui
Thank you for the prompt reply. Checked those points. It must be the control board, but those are not manufactured anymore and can't find one in stock anywhere.
Found a place in Austin to send the board itself for repair for a little over $100. Otherwise looking at thousands to replace the whole double oven. Hope they will be successful; no cost if they aren't, so nothing to lose now.
I really appreciate this site and it's helpful experts. :)
Joe / APP Team
#4 Posted : Tuesday, April 5, 2011 5:12:50 AM(UTC)
Joe / APP Team
Mais,
We're happy you have it diagnosed.
I was hoping you wouldn't need the control board, that does happen, occasionally.
Most remanufacturers are really good as far as rebuilding and upgrading, control boards, I think you'll be fine when you get it back.
Good Luck,
