4018
#1 Posted : Monday, October 22, 2007 6:44:17 PM(UTC)
4018
The dryer doesn't want to start on any heating setting, but if you put it on the cool down cycle it will run. It started getting worse about two months ago. You could set it for sixty minutes and it might run but if you put it on a lesser amount of time it would run. Now it has decrease until it will not start at all on any heating cycles. I checked the thermal fuse and it checks OK. I checked the thermal cut-off for the dryer element and it has continunity when cold. What should I check for next? Do you think I might have problems with the timmer control?
richappy
#2 Posted : Tuesday, October 23, 2007 1:34:58 AM(UTC)
richappy
I usually pull timer apart on these to confirm bad contacts. Also, you can check timer contacts per the wiring schematic.
