Miss
#1 Posted : Monday, October 22, 2007 4:38:13 PM(UTC)
Miss
WE have checked the exhaust duct and it is clear. The dryer heats for about 10 to 15 minutes and then stops heating. The gas flame ignits but goes out in about 10 to 15 minutes into the cycle. It still tumbles, however.
#2 Posted : Monday, October 22, 2007 4:56:16 PM(UTC)
Hi MISS
If the flame ignites only a few times at the beginning and then the igniter glows but the gas does not coming out, then the problem is a bad coils on the gas valve. Replace them and the problem solved.
The set of the coils
UserPostedImage
- The part number for the set of the gas valve coils AP3094251
- Here are the break down diagrams for the Maytag dryer Model MDG9316AWW
Good luck.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Gas dryer problem, GGW9250PW service manual needed (Dryer Repair)
by ergmeister 5/11/2012 11:52:27 AM(UTC)
Gas Dryer problem (low/no Heat) (Dryer Repair)
by rkurelowech 9/14/2010 9:15:16 AM(UTC)
maytag bravo gas dryer problem (Dryer Repair)
by bugjuice 7/14/2010 10:26:02 AM(UTC)
Gas dryer problem (Dryer Repair)
by witsend 2/11/2008 5:50:29 AM(UTC)
GE gas dryer problem (Dryer Repair)
by joe75 11/30/2007 4:24:28 PM(UTC)
