fotografie
#1 Posted : 14 years ago
fotografie
dryer had been working fine; I went to swap loads and found that although the clothes in the dryer were mostly dry, it had stopped before it finished its cycle, stopping in the cool-down stage. I tried turning it back on, but the start button won't start the dryer. I checked the fuse box in the house, it didn't trip, and the light is still on inside the dryer, so I don't think it's a main fuse. it just won't turn on. any ideas?
sidfink43
#2 Posted : 14 years ago
sidfink43
The main things to check are
1. The door switch, check it for continuity when the door is closed.
2. The push to start switch (less likely to be a problem)
3. The timer (also unlikely)
4. The thermal fuse, which is most likely to be the problem. Test it for continuity, if it is open replace it. Then clean out the dryer because the main reason the fuse blows is insufficient air flow from lint blockage.
Always work with the dryer unplugged.
fotografie
#3 Posted : 14 years ago
fotografie
as it turns out, the dryer is fine and works great. the problem was with the electrical receptacle in the wall. it was loose and at some point started to burn (I could see the melted plastic around the prongs on the dryer plug, and the one that blew had a discolored prong, it was obvious). I had checked the fuse box of course and nothing was tripped, but it fried one side of the 30amp receptacle so it wasn't getting juice. if it had been the other side that fried, the dryer would have ran but wouldnd't have gotten any heat — but because it was the side that handed power to the unit, it wouldn't run. I replaced the receptacle (I got a 30 amp outlet for less than $6 at home depot) and everything is working fine now. I considered replacing the plug on the back of the dryer but haven't done that yet.
thanks for the help, and I hope this helps someone else! next time, I will check the prongs on the plug in addition to the fuse box just in case. learn something new every day.
sidfink43
#4 Posted : 14 years ago
sidfink43
Well very good, we always tell folks to check to make sure they are getting 220 volts to the dryer, but sounded like you had done that so I forgot to mention it.
Glad you got it fixed and thanks for updating us. This kind of feedback is very helpful.
Maytag Atlantis Dryer Ignites, Blows Gas/Flame then shuts off (Dryer Repair)
by pzazzera 6 years ago
Alternate timer for Maytag Atlantis dryer (Dryer Repair)
by thorning 10 years ago
Maytag Atlantis Dryer timer which one? (Dryer Repair)
by Stevenerd 10 years ago
Maytag Atlantis Dryer peoblems (Dryer Repair)
by rockworthy 13 years ago
Maytag Atlantis Dryer not starting (Dryer Repair)
by herb191 13 years ago
Maytag Atlantis dryer....LOUD squeaking noise (Dryer Repair)
by kimber23ks 14 years ago
Maytag Atlantis Dryer won't shut off (Dryer Repair)
by TJ68 14 years ago
Maytag Atlantis dryer will not shut off (Dryer Repair)
by meano 15 years ago
Maytag Atlantis Dryer (Dryer Repair)
by Honker 15 years ago
