Its runs, but there is no heat. After looking at other posts I verified there is 115 v on each leg at the outlet and 230 across the legs. I checked the resistance of the heating elements, both at 20 ohms, and verified continuity of the 2 thermoswitches near the heater and 2 near the blower. There was another smaller switch, I think, located between the 2 thermoswitches near the heater that also had continuity. I even bypassed the temp selector switch. Since all this stuff can only be accessed with the drum removed I bypassed the broken belt and door switches to get it to run in its evicerated state.
Any other suggestions?
Perhaps the heater switch on the motor's centrifugal switch assy is not closing OR a set of timer contacts |
THIS FORUM IS DEAD!!!!!!! |
