AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer agitates normal then slows down and stops.
I have a GE WJSE3110AOWW washer. It works fine until it gets to the 6 minute cycle. Once inside the 6 minute cycle it agitates normal for a short while and suddenly slows down so that it barely agitates and eventually stops. It stays this way until this cycle is complete and then continues normally through the rest of the wash.
See if this happens during a different timer cycle.
No, it doesn't. Just in the 6 minute cycle.
Then that confirms a bad timer; I would pull the cover off and verify burnt contacts. Just click on your model # to get parts.
Washer Repair
