You have been a member since:: 1/3/2009(UTC) Posts: 1
When I try starting the dryer, the sensing light comes on and there is a single beep. But it will not start. As if there is a cut off. Is there anything I can do to find out more? Is there a diagnostic test that might give an indication? I read where a repair technician removed the front of the dryer, vacuum'd and it then it started. I had a large down coat with a gym shoe (to bounce and fluff the garment). That was the last thing I dried. I hope someone can help. My email is plf999@aol.com.
Remove the toe panel and check if the belt is not broken. There is a special "belt broken" switch which prevents the dryer from start if the belt brakes. Here are the break down diagrams for the Whirlpool dryer Model GGW9250PW0Gene.
I have the same problem. Both the belt and fuse are Ok. What did you find was the problem?
Found nothing yet. I relly need the help. It's not the belt because the drum turns when I press the More time & Less time buttons. It shuts off after a short time
Ok in your initial post you said it has a single beep and doesn't start or turn at all?......now your saying timed dry turns for awhile then shuts off?
I had to order the Control & Display Board from Sears Parts. It will take 5 - 7 work days.
