Rank:: Member
My broiler element won't shut off. Is it a relay? I have to cut the breaker switch. Also the clock is not illuminated so I can't see the codes. And one more thing. The down draft fan stopped working, first at one speed then both. Not sure if I would have to replace the fan motor itself or the board. Since the fan won't work the oven won't clean as well. Lot's of problems but still cheaper to fix than to buy a new unit. I wopuld also need the service/repair manual to fix this. Can you help?
Thanks, Willa
Hello Willa. Here is the repair manual you were looking for. Part number: AP4018285
There are several test for the problems your having listed in the manual. Hope this helps.
