jws058
#1 Posted : Saturday, March 19, 2011 11:30:09 AM(UTC)
jws058
I have a Kenmore washer about 11 years old that will not spin at the end of a cycle but will drain and spin in between the wash and rinse of the main wash cycle. Is this a timer control problem?
sidfink43
#2 Posted : Monday, March 21, 2011 11:05:27 AM(UTC)
sidfink43
Since it will through a complete wash cycle (fill, agitate, drain, spin,) then there does not seem to be a mechanical problem, so the like problem is the timer.
Try disconnecting, cleaning and resetting the connections to the timer first and see if that helps, probably won't but worth a try.
