Mary Jain
#1 Posted : Friday, March 18, 2011 12:12:47 PM(UTC)
Mary Jain
mI changed the flat igniter. Now the igniter works but gas does not go in the oven.
Mary Jain
#2 Posted : Friday, March 18, 2011 12:18:31 PM(UTC)
Mary Jain
I changed oven igniter in 36275191891. Which works. Now the gas is not going in the oven. What may be the problem.
Kenmore gas range problem (Oven Repair (including Ranges and Cooktops))
by Rob66 12/22/2019 3:38:16 AM(UTC)
Kenmore GAS Range. Model:79079013101 won't bake heat (Oven Repair (including Ranges and Cooktops))
by jfii 12/6/2019 12:56:05 PM(UTC)
Kenmore Gas Range will not stay lit more then 5 seconds (Oven Repair (including Ranges and Cooktops))
by AlexMiles 2/28/2017 5:23:58 AM(UTC)
kenmore gas range (Oven Repair (including Ranges and Cooktops))
by dennishazard 1/5/2017 8:03:49 AM(UTC)
Kenmore gas range oven won't work (Oven Repair (including Ranges and Cooktops))
by shirleyjones 12/14/2016 10:41:41 AM(UTC)
Kenmore gas range bottom burner not working (Oven Repair (including Ranges and Cooktops))
by scott mcgourley 10/29/2013 9:09:28 AM(UTC)
Kenmore Gas range hase low flame on all burners and in oven (Oven Repair (including Ranges and Cooktops))
by eddyr123 9/11/2013 12:37:23 PM(UTC)
Kenmore Gas Range PF code won't reset (Oven Repair (including Ranges and Cooktops))
by mklindsey 2/20/2012 5:40:08 PM(UTC)
Kenmore Gas Range F3/F6 error codes (Oven Repair (including Ranges and Cooktops))
by ruju 4/25/2011 9:08:22 PM(UTC)
Kenmore gas range clock gains time (Oven Repair (including Ranges and Cooktops))
by bayhollow 4/7/2010 4:40:51 PM(UTC)
Kenmore gas range contol panel problem (Oven Repair (including Ranges and Cooktops))
by scba911 4/5/2010 7:51:28 AM(UTC)
Question about Kenmore Gas Range Control Panel (Oven Repair (including Ranges and Cooktops))
by Xelveki 1/4/2010 9:31:21 PM(UTC)
Kenmore Gas Range (Oven Repair (including Ranges and Cooktops))
by wmichalk 12/29/2009 9:48:07 AM(UTC)
kenmore gas range knob (Oven Repair (including Ranges and Cooktops))
by femmo 12/14/2009 5:30:28 AM(UTC)
Kenmore Gas Range bake/broiler wont work (Oven Repair (including Ranges and Cooktops))
by stillinkent 11/18/2009 12:16:30 PM(UTC)
