Can you tell me how to find the Door Switch for the above model number. The error code indicates that the switch is bad and needs to be replaced. I need to know how to find this switch.
Hi, The door switch is #12 in the diagram. ![UserPostedImage](http://www.appliancepartspros.com/sect/5/4/r/54rz53zjjj.gif)
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi, The door switch is #12 in the diagram. ![UserPostedImage](http://www.appliancepartspros.com/sect/5/4/r/54rz53zjjj.gif) Is this switch also tied to the system that keeps the self cleaning operation from functioning? That is the only time we get the error code which also stops the self cleaning operation. Thanks for your help with this.
