kobeplace
#1 Posted : 14 years ago
kobeplace
My Maytag wont spin. It tries to spin (However it makes a loud noise) like a teacher using fingers on a chalk board, then it comes to halt.
I change the brake rotor, thrust bearing kit, belt, stator, spring, timer, yesterday. I did notice when taking off the brake parts, it had no snubber ring, so by instruction from someone.. i put back the brake like it came off, with out the snubber ring..
When I tried to put the Snubber ring on - it seem to not fit because of the off center position the washier was in i guess.. so i just left it off... Can someone help me with releasing the brake it seem to be stuck.
sidfink43
#2 Posted : 14 years ago
sidfink43
Well I don't think it is going to work without the snubber
Here is a link to a service manual for your model.
Search Form - ApplianceDigest.com
