cityservices
#1 Posted : 17 years ago
cityservices
I have combo oven/micro built-in. The interior light for the micro is burned out...how do I get to it for replacement. There is no cover panel on the interior to access the bulb and according to your parts diagram, I think it has a lens cover that prevents me from getting to the bulb from the microwave interior...thanks for your help. I'm pretty mechanical as I recently replaced the oven latch assembly for this same unit...thanks again
rozman
#2 Posted : 16 years ago
rozman
hello! i have the same combo and i was wondering if i could get a diagram for replacing the bulb in the microwave. do you have a manual that shows the light bulb or tells you ow to replace it? thank you.:confused:
TechnicianBrian
#3 Posted : 16 years ago
TechnicianBrian
Rozman, you said you have the same combo as Cityservices, but then you put GE light bulb replacement as your subject so I want to make sure we are getting you the right information. Starting a new thread with a model number would be a great help to get you going in the right direction.
Kitchenaid Superba Microwave Bulb replacement (Microwave Repair)
by garyeruss 14 years ago
Jenn Air Microwave Bulb Replacement (Microwave Repair)
by VWC 16 years ago
