My Microwave just went dead. I checked the circuiy breaker and it's fine. Does this model have a fuse that maybe I can replace?
Thank you!
Check your model number and you will find diagrams showing where your fuses are. Usually behind the control panel... Look for a screw to remove it and it may just pop out from the bottom of the panel. Open the fuse holder and either check the fuse for continuity or replace it with the same type. Make sure you have power to the circuit and /or the outlet. Good luck!
