I also have Kenmore same model ,Did all the same test ,Transformer,Cap,Diode all results normal as per test tech-sheet . Will a Magnetron make a loud noise ? Thank You.
Originally Posted by: Why42 ...Will a Magnetron make a loud noise ?... Yes it's possible, especial if there is continuity between each of the two terminals and the body of the magnetron. Gene.
Magnetron - Continuity between each of the two terminals good .7 ohm --Terminal to Body infinite. I see it arcing inside the magnetron terminal box form a small hole in corner of box . CK HV Cap with a 9V battery and meter -Terminal to Terminal 9V ------Terminal to case 0v same results as info in tech-sheet . Diode with 9v test CK good . Magnetron ??? Any other way to test it ? Thank You.
Originally Posted by: Why42 ...I see it arcing inside the magnetron terminal box form a small hole in corner of box... The magnetron is the culprit. If you need the correct part number, post the complete model number of the microwave. Gene.
Kenmore 721 6325930 Tag on Magnetron LG 2M246 05GF ::
Thank You.
Thank You !!!! Your A1 !!!
