I am trying to replace the door glasses in a Kitchenaid oven that were removed by someone else.
1. I have two clips (ref 23 on the schematic, part no. 4451432). They have two elongated holes that appear to be screw holes. Where (specifically) do they go?
2. The top corners of the middle glass piece (of three) slides under the tabs in the Glass Retainer (ref 5, part no. 8300778). Does the third piece of glass lay right over the middle piece. If so, what hold it's top corners in place?
:confused:
