I have two issues with this dishwasher, which may actually be only one issue but here they are. The dishwasher is leaking over the top of the right corner of the kickplate. We ran a rinse cycle through it with nothing in the dishwasher - no dishes or soap and it had lots of suds inside the tank. I took a towel and wiped out the suds that were left after we drained it(drained it through the actual cycle on dishwasher). Nothing has ever been put into the dishwasher that would cause it to sud up - no regular dishwashing liquid, all spills of jetdry have always been wiped up and not allowed to remain.
Thank you for your help.
Have you changed detergent? Is it working ok now?
No, I have not changed detergents. Other than the sudsing and the leak everything else works fine. Originally Posted by: Jeff / APP Team  Have you changed detergent? Is it working ok now?
We need to get all the suds out of the unit to see if this stops the leaking. Run the unit with no soap or dishes and use 2 table spoons of vegetable oil. Then run the unit through a 2nd full cycle with no soap or dishes to finish cleaning out. Try cutting down on the amount of soap and see how it does. Hope this helps.
Still sudsing and still leaking out over top of the right corner of the kickplate. No detergent has been put in...run through several rinse cycles.
make sure jetdry isnt leaking you may have to remve the inner panel it may be leaking there
We removed the inner dishwasher door panel and saw that there was alot of jetdry that was on the back of the panel. I don't think it is leaking but what was there was probably a result of numerous overfills . Washed it all off and I think it's good to go. I appreciate your help in this. Saved us a minimum of $69 for a visit from a local repair shop.
