3 Pages<123
Guest
#21 Posted : about a year ago
Guest
Groups:
THX for the details on testing the RPM- huge help. Mine were running over 3K. Thermador double oven (SEC model 2005). I have been receiving F64 codes and they were getting worse and worse. I flipped the breaker to the oven, stacked cinder blocks and wood in front of the oven, and slide it out onto blocks. I then pulled off the back and top to access the fans. I used a shopvac, toothbrush, 100 (seemingly) Q-Tips, and a acetone. I gently scrubbed the fan blades until shiny. The amount of junk that came off was incredible- cups of junk. I put everything back and did a fan test- 2400. Oven has been running for over an hour at 400. I searched everywhere and this is the only place with accurate info- THANK YOU!
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 about a year ago
Heating issues with Thermador Oven (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
Thermador oven temperature fluctuates (Oven Repair (including Ranges and Cooktops))
by tylert 3 years ago
Thermador Oven issues PGR36GL (Oven Repair (including Ranges and Cooktops))
by aquasport 5 years ago
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 5 years ago
Thermador Oven Selector Knob at Broil Shuts Off oven (Oven Repair (including Ranges and Cooktops))
by dviladvct1 5 years ago
Thermador Oven Not Turning On- Tech no help (Oven Repair (including Ranges and Cooktops))
by annie1123 5 years ago
Thermador oven help (Oven Repair (including Ranges and Cooktops))
by Lepetitmatin 6 years ago
Thermador oven won't fire up (Oven Repair (including Ranges and Cooktops))
by cattleclass 7 years ago
by Gandv 7 years ago
Thermador oven stopped working (Oven Repair (including Ranges and Cooktops))
by ajappliance 9 years ago
Thermador Oven Inop (Oven Repair (including Ranges and Cooktops))
by JakeM7pilot 9 years ago
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9 years ago
Thermador oven won't regulate (Oven Repair (including Ranges and Cooktops))
by stanmac 10 years ago
Thermador oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by fixitboy 11 years ago
3 Pages<123
