My Sears refrigerator icemaker has quit filling with water. I've tested the water valve and get a good ohms showing, so I'm thinking a timer or something is not energizing the solenoid.
Can you describe the "fix" and advise if it is something worth fixing that I might do myself? It was purchased in 1991.
If the valve is good, and your fill tube that drops the water into the icemaker is not frozen, you then need to replace the ice maker motor module. It is real easy to replace. The part # is W10190935 Tom
