Thank you for your effort and information.
Costwise, I'll be better of buying an inexpensive washer.
Reusam
Originally Posted by: ReuSam ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you for your effort and information.
Reusam Reu, You're welcome, It was a pleasure to help. Should you change your mind, we'll be here to help. Good Luck, :) :) :)
Joe,
I thought of dropping you a line to let you know that I had the washer working about two weeks after our last conversation. Initially,when I inspected for any obstruction inside the tranny (none found), #26 on the diagram, the plastic and metal clip came off gear # 25. When I put them together, I put the plastic with an "UP" marking side towards #25 (as if the whole unit in upright position). I downloaded the gearcase assembly drawing and noted that #25 should have been flipped over which I did.
Lo and behold the washer is working properly again.
Hopefully this information might help down the road.
ReuSam
Originally Posted by: ReuSam ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Joe,
ReuSam ReuSam, Thanks for the update, it'll come in handy, for sure. We're glad you're up and running properly again. Thanks again and Good Luck, :D :D :D
