spedteacher
#1 Posted : Monday, February 14, 2011 8:49:54 AM(UTC)
spedteacher
Kenmore 80 series heavy duty model # 110.92281100
Was making weird noise during wash, like it was working too hard. There was Not a heavy load in it at the time.
Now it WONT drain. Timer knob moves to the correct setting then the washer makes this buzzing noise and does nothing.
The washer also smells hot.
Do I need to add oil ? If so ,how? where?
Why wont it drain?
Jeff / APP Team
#2 Posted : Tuesday, February 15, 2011 7:09:37 AM(UTC)
Jeff / APP Team
The first thing you need to check is the pump on the unit. Make sure nothing is stuck in the pump. If so you will need to replace the pump on the unit.Part number: AP2907492
