sloka
#1 Posted : Sunday, February 13, 2011 2:09:03 PM(UTC)
sloka
GE Double wall oven - Microwave is not working. Convection oven is working. Iam assuming it might be the fuse. Could anyone send me the service manual for JTP85BA5BB. If anybody has anyother ideas let me know.
abadfish66
#2 Posted : Sunday, February 13, 2011 5:15:47 PM(UTC)
abadfish66
When you turn the microwave on to cook, does the turntable rotate?
sloka
#3 Posted : Monday, February 14, 2011 8:08:18 AM(UTC)
sloka
Microwave doesn't work at all. When i press any button it does nothing. No power supply i guess.
sloka
#4 Posted : Saturday, February 19, 2011 7:16:46 PM(UTC)
sloka
Microwave is running (light is on, turntable is turning), BUT, it is not heating the food. Also, there is a pungent smell when i run the microwave.
I checked the following using an analog multimeter:
Diode: shows 0 reading in both directions when testing only with multimeter. when testing with multimeter & 9V battery, it was showing infinity in both directions.
Transformer:
-resistance between primary input terminals: zero ohms
-terminal 5 to chassis: zero ohms
-terminal 4 to 3: zero ohms
Magnetron:
-across filament leads: zero ohms
-one lead to chassis: infinity
-other lead to chassis: infinity
Can anyone please help!
Old GE Double Wall Oven - Top isn't working (Oven Repair (including Ranges and Cooktops))
by Doubletheoven 11/25/2022 5:19:46 AM(UTC)
GE Double Wall Oven jt5500sf5ss doors locked with no power after self clean (Oven Repair (including Ranges and Cooktops))
by mtvu11 9/28/2019 9:19:27 AM(UTC)
older GE double wall oven challenge (Oven Repair (including Ranges and Cooktops))
by WiiGame 3/29/2014 12:06:50 PM(UTC)
GE Double wall oven (Oven Repair (including Ranges and Cooktops))
by Bongomon 3/5/2011 1:44:23 PM(UTC)
