tonia411
#1 Posted : Friday, February 4, 2011 5:50:39 PM(UTC)
tonia411
We had a power surge into our home tonight and now we do not have any power to our control panel on our dryer.
#2 Posted : Saturday, February 5, 2011 12:35:58 AM(UTC)
Here are your parts includes wiring diagrams
Replacement parts for MAYTAG MDE5500AYW DRYER- ELE | AppliancePartsPros.com
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If the power is OK then odds are that the control board is toast.
bill von
#3 Posted : Tuesday, February 8, 2011 5:03:41 AM(UTC)
bill von
dryer light comes on, no control board all connects look find.. is their a reset..or any other part other then control board model #mde6800ayw
thanks
Maytag Dishwasher control panel doesn't light up (Dishwasher Repair)
by ms031317 11/20/2013 12:16:24 PM(UTC)
