garryusbonds
#1 Posted : Friday, February 4, 2011 12:43:06 PM(UTC)
garryusbonds
I am having my kitchen remodeled and have moved the dishwasher in and out a few times. Since then the spring action on the doors is noticeably louder (even allowing for the sound dampening panel removed) and a slow drip which seems to be coming from the left bottom side of the door during the spray cycles. Any Suggestions??
#2 Posted : Friday, February 4, 2011 2:26:43 PM(UTC)
Pull the dishwasher out of the cabinet enough to see the door hinges and springs. Inspect the hinges, springs and cables on both sides. Post the results.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FDB2415LFC0 Frigidaire/dishwasher | AppliancePartsPros.com
garryusbonds
#3 Posted : Saturday, March 12, 2011 10:39:45 AM(UTC)
garryusbonds
Gene:
Sorry for the delay since your response. Pulled out dishwasher and the springs, cable and arm assembly seem to be OK. I ran my finger along the bottom door gasket and there seems to be about a 12" piece missing in the middle. I can't tell from the part photo whether this is normal.
#4 Posted : Saturday, March 12, 2011 2:50:01 PM(UTC)
Are you sure the door is not dislodged?
garryusbonds
#5 Posted : Saturday, March 12, 2011 3:10:34 PM(UTC)
garryusbonds
The door fits securely around the the sides and top, and the latch catches so I don't think the door is dislodged. Is there a way to ensure that the bottom is hinged correctly?
#6 Posted : Saturday, March 12, 2011 3:23:47 PM(UTC)
Very likely the cause of this problem as well as the solution are described in the document attached to the reply.
- The bottom door gasket Part number: AP3959846
File Attachment(s):
garryusbonds
#7 Posted : Saturday, March 12, 2011 3:26:27 PM(UTC)
garryusbonds
Thanks, for the price of the part, it's worth a try.
I'll let you know.
garryusbonds
#8 Posted : Saturday, April 23, 2011 5:19:03 AM(UTC)
garryusbonds
I installed the part you recommended, a bottom door gasket, and I also installed side splash shields upon recommendation at the parts store. Thanks for your help.
I have another problem with the DW since moving it around. The springs creak and moan like a dungeon door every time we open and close the door. All the parts seem to be in place. Do you have any suggestions for dampening the noise??
Guest (6)
