saltima
#1 Posted : Wednesday, December 3, 2008 7:27:48 AM(UTC)
saltima
my dryer belt keeps falling off pulley. any suggestions?
#2 Posted : Wednesday, December 3, 2008 10:48:49 AM(UTC)
Here is your parts breakdown
Model CDE9500W
Here is how it should look when installed
http://www.applianceaid.com/images/belt-config.JPG
Is there a fair amount of tension on the belt when it is installed, there should be. If not the spring is weak or the belt has stretched.
Check the idler wheel
Check to be sure the drum rotates fairly easily
