Replacing lg oven door hinge on GE Monogram stove model ZDP48N6DW255, S/n #RT2013537 and need to know in detail:1) how to remove door from 27" oven and then 2) how to remove bad (R) hinge from inside door and 3) replace with your part #GEH WB10X5226 and then 4) how to reinstall oven door.
Steve, The instructions on how to remove/reinstall the oven door you can find in the Installation instructions (page 12). The door hinges are inside the door.The door has to be partially taken apart to access the hinges. Unfortunately I did not find more specific instructions on how to take the door apart. GE part number WB10X5226 is Appliance Parts Pros Part number: AP2020461
