madge
#1 Posted : Saturday, January 15, 2011 6:43:49 AM(UTC)
madge
My whirlpool dryer drum is not turning, and in the back the heating element smelled like it was burning. I took off the lid and back and it appears that the belt is still in tact. Is it a thin belt around the middle or a thicker one near the back? Both are still in place. What shall I do now? It is about 10 years old
Joe / APP Team
#2 Posted : Saturday, January 15, 2011 8:44:13 AM(UTC)
Joe / APP Team
Madge,
A model number would have been a great help,
But,
Your vintage of machine, should have a drum drive belt, approximately 1/2 inch wide and slightly off center of the drum.
The large black "belt" at the rear of the drum, is most likely the drum seal.
As I understand this, you can start the unit, the unit heats, but the drum does not turn/tumble the clothes, correct ?
Can you hear the motor running, or if you remove the exhaust vent can you feel the hot air blowing out the tube ?
If you open the door or turn the machine off, does it stop heating ?
At this point, I think you may have a bad motor switch/motor, but can't be sure without some additional information,
Thanks,
