MistyRain
#1 Posted : Tuesday, January 11, 2011 12:10:11 PM(UTC)
MistyRain
I have an admiral brand dryer, model number ADE7005AYW. Have only had this dryer maybe two and half years. It started squeaking off and on a couple months ago, but now it squeaks continually when it is running. It heats and dries the clothes fine. Can you tell me what may be the problem with it, the parts to buy and their numbers and how to go about opening it to fix it? Thanks.
#2 Posted : Tuesday, January 11, 2011 2:19:17 PM(UTC)
Remove the front panel and the front bulkhead. Check the front glides (#3 on the diagram). Both glides have to be replaced at the same time.
- The front drum glide (order two) Part number: AP4046795
mecnc
#3 Posted : Thursday, September 8, 2011 6:31:06 PM(UTC)
mecnc
I have the exact same model as listed above with the same problem. I replaced the glides and it still squeaks. While I had the front off I inspected the drum rollers and they looked fine as did the belt. What should I do next?
