The top coil of my oven will not turn off, I had to unplug oven. Hours later I pluged back in and the top coil immediately turned on and will not turn off. Does anyone know what this may be?
What is the Complete model number of the oven?
Model number 665.95781000
Sounds like the problem is a relay on the control board stuck closed. The control board has to be replaced. - The part number for the control board is AP3174668 Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Sounds like the problem is a relay on the control board stuck closed. The control board has to be replaced. - The part number for the control board is AP3174668 Gene. Gene, Thank you, that is what I thought. That is one expensive repair.
