AlloyGT
#1 Posted : Wednesday, November 26, 2008 10:35:40 PM(UTC)
AlloyGT
My girlfriend has complained that our range is tripping the circuit breaker quite often. I tried to get her pinned down on details, but she couldn't really tell me if it is limited to the oven, or one particular burner.
I just tried using the oven. It turned on OK, started heating, and then all power on the range went off. I went outside, reset the circuit breaker, and a few minutes later it did it again. All in all, this happened 4 times, in trying to get the oven heated to 350. It is rather chilly out tonight, and it seemed to me that the circuit breaker was a bit warm when I reset it...not hot, but it felt slightly warmer than the one below it.
After reaching 350 finally, the oven seems to be working fine. The element is cycling on and off, and it hasn't tripped the breaker in over 40 minutes. Tomorrow, while we're trying to cook Thanksgiving dinner, I will see if any of the burners seem to be making the breaker trip too.
Any ideas what is going on with this thing?
Thanks!
#2 Posted : Thursday, November 27, 2008 2:44:14 AM(UTC)
Sounds like the breaker needs replacing, at least that is the first thing I would try.
v2k04
#3 Posted : Thursday, November 27, 2008 2:57:31 AM(UTC)
v2k04
Agreed...If it was the Range it would snap instantly as soon as it was turned on
AlloyGT
#4 Posted : Thursday, November 27, 2008 7:59:37 AM(UTC)
AlloyGT
That was my first thought. But I had a discussion with a guy (granted it WAS at a bar) who said he has been an electrician for over 15 years, and said he has never seen a circuit breaker go bad like that. Which is why I was wondering if the stove could be the problem.
Last night after I posted, had the oven on at 350 for about an hour with no problems. Then had a burner on for 45 mintues or so, no more incidents.
G/f started baking a pie this morning....it tripped 4 times, including once where she couldn't get the breaker to reset until she turned the oven all of the way off....but it's fine now.
We have to cook a ham and a turkey, and all of the trimmings today...keeping my fingers crossed!
#5 Posted : Friday, November 28, 2008 4:00:16 AM(UTC)
I have had to replace a breaker because it was tripping at a lower current then it should have.
Other possibilities are:
1. The breaker is not making good contact in the box. remove it and check that the rails etc. are corrosion free and wires going into it are good. Also check that it snaps in or screws in tightly.
2. Poor connection or corrosion at the wall receptacle for the unit or in the wire nuts if it is hard wired.
3. Poor connection or corrosion in the oven at the terminal strip
4. Something is heating up, softening and then shorting out. But I would expect that you would hear and/or smell this. Open it up and check for any burn marks on the frame.
