Our 1999 Kenmore 25 cu/ft refrigerator stopped cooling/freezing all of a sudden. This is the first instance of any problem, since purchased new. Had not adjusted any controls in years. I did notice over several months that it was noisier when it was "running". The question is, should I call the Sears repairman or go buy a new one? I am not able to repair it myself, unless it's relatively minor.
Need more info on what is happening.
What are the symptoms? Is the compressor running? Is the condenser/compressor fan running? Is the evaporator (freezer) fan running? Have you tried turning the temperature to off and then back to a cold setting? |
THIS FORUM IS DEAD!!!!!!! |
denman: thanks for your questions; we decided to replace the unit with a new one.
