Our electric GE dryer will not heat up. The timer still works, drum turns, etc. Thinking the problem might be something like a heating coil. How do I repair that? Where would I find the coil, if that's what it is?
There are a number of things that will make any electric dryer not heat.
It could be a bad heating element, thermo fuse, timer, motor switch or even one leg of the 220 voltage missing.
