None Of the burners are working on the cooktop of my stove. I cannot locate info on any of my documentation for it to tell me what the voltage output on the transformer should be. Do you know what it should be.
THIS FORUM IS DEAD!!!!!!! |
I am wondering if you have a power problem. You might want to check where the power comes into the stove. Alot of times, that is where, the wires burn. Tom ApplianceEducator.com
Originally Posted by: denman  Thanks, I will look this link over and see if I locate what my problem might be.:)
Originally Posted by: kayakcrzy  I am wondering if you have a power problem. You might want to check where the power comes into the stove. Alot of times, that is where, the wires burn. Tom ApplianceEducator.com I have checked where the power comes in and all checks out good there. No burned wires. Thanks anyhow.:confused:
Did you take a voltage reading?? All burners don't go out at once!! There has to be a power issue. Tom ApplianceEducator.com
