fredeline
#1 Posted : Tuesday, November 25, 2008 5:24:45 AM(UTC)
fredeline
Troubleshooting failure for drain motor to turn off whenever on button pressed and dishwasher won't go through cycles. Need electrical schematic diagram. Thanks, Fred
#2 Posted : Tuesday, November 25, 2008 1:33:25 PM(UTC)
Remove the toe panel and check for water in the base under the dishwasher. Most likely there is a water leak.
You can find the quick check chart in the break down diagrams for the Bosch dishwasher Model SHU3036 UC/12 (FD 8003-)
fredeline
#3 Posted : Tuesday, November 25, 2008 2:30:35 PM(UTC)
fredeline
Gene - thanks for the reply but no help - I've already looked at the diagrams referenced and need the electrical schematic diagram. Also, no leaks - pump motor just keeps running and it won't respond to any other command (like wash). Please send the electrical schematic diagram if available. Thank You, Fred
#4 Posted : Wednesday, November 26, 2008 11:07:36 AM(UTC)
Fred,
You can use the troubleshoot manual from one of our previous posts: http://forum.appliancepartspros...troubleshoot-manual.html
Unfortunately I do not have the wring diagram for this model.
fredeline
#5 Posted : Wednesday, November 26, 2008 11:13:24 AM(UTC)
fredeline
Gene - You are the Man!! I followed the guide in the previous posts - actually started there. It runs out of gas and really need the schematic diagram - Bosch won't supply it as I've tried. Appreciate your time and posts and wish you the very Best Thanksgiving Holiday! Fred
