All of a sudden my Roper dryer stopped....we noticed it had begun to need two cycles to completely dry a load....what can I do to revive it??
You will want to check the white plastic thermofuse located on the vent housing on the back of the dryer after removing the back panel, if it is bad replace it and clean out your dryer vent to the outside since blocked air flow is what blows these fuses.;)
