Michaele
#1 Posted : Monday, November 24, 2008 3:21:47 AM(UTC)
Michaele
I had a full load (but in no way overloaded) in washing machine on warm/cold. It washed and got to the point right before rinse and just came to a stand-still. Full of water and soap - not draining. Checked the drain hose and it was not bent. Tried to agitate the agitator - nothing. Unplugged and replugged. Flipped the breaker switch. Stuck my hand in all the way to make sure nothing was stuck or caught or wrapped under the agitator - all was fine. Spun the dial to different settings - nothing. When I moved the load setting from SMALL to MEDIUM to LARGE a small bit of water came out with each click to the different capacities like it was filling the washer - but nothing happened. Checked the switch that is depressed when the lid is closed. Not sure what to do next. Had to remove all clothes - wring them out and removed water by hand from washer - still nothing happening. Thanks for any advice!
v2k04
#2 Posted : Monday, November 24, 2008 7:00:52 AM(UTC)
v2k04
When You Say You Checked The Switch What Did You Do To Check It?
Michaele
#3 Posted : Monday, November 24, 2008 8:59:16 AM(UTC)
Michaele
I just lifted the lid and depressed the button wuth the end of a hanger to make sure that it was able to depress and wasn't stuck. I am by no means handy - and my husband is in Mexico! I was looking to see if there was anything I could do (easily).
richappy
#4 Posted : Tuesday, November 25, 2008 3:13:14 AM(UTC)
richappy
Does the washer motor make any noise in spin?
