you have any idea why my Whirlpool dryer was working in the morning and not working in the evening. I have replaced the on/ff switch and you can here the timer ticking it is 6 years old
Did I miss the model number to see what is in your dryer? Suspect the white plastic thermofuse may be open if the dryer is dead then clear out your blocked dryer vent to the outside, if the fuse is good check the door switch...best can do without knowing what is in your model...:confused:
