hatchchuck
#1 Posted : Friday, December 24, 2010 3:54:54 PM(UTC)
hatchchuck
The dishwasher has stopped functioning. There are no lights on the control panel and there is standing water in the base of the unit.
I had an earlier issue with the touch panel and it was replaced. At that time the control panels lights would flash.
This time there is nothing. I confirmed there is power to the unit.
#2 Posted : Sunday, December 26, 2010 3:48:18 AM(UTC)
Replacement parts for KUDS40FVPA models | AppliancePartsPros.com
Check that the unit is getting power.
Check the thermal fuse Item 5 in Section 2
If blown be sure to use the harness that comes with the replacement fuse.
Could also be a door switch is blown or not closing.
