martyknite
#1 Posted : Tuesday, December 21, 2010 10:33:27 AM(UTC)
martyknite
how do i replace oven glass (inner)
Joe / APP Team
#2 Posted : Wednesday, December 22, 2010 6:16:30 AM(UTC)
Joe / APP Team
Marty,
Here's a step by step general teardown procedure for your style KA Range.
I take for granted you've already orderred the inner glass ?
Good Luck,
1. Remove the oven door from the range
2. Place the oven door on a padded work
surface with the decorative glass and
handle facing up and the bottom edge
facing the front.
3. To remove the decorative glass and
handle:
a) Remove the screw from each of the two
decorative glass retainers, and remove
the retainers.
b) Turn the door 180ー so the handle faces
the front.
c) Remove the two door handle bracket
screws.
d) Lift the bottom of the decorative glass
and slide it down so the top clears the
lip of the liner, then lift the glass and
handle off the door liner assembly
e) Remove the two door handle screws
from each of the brackets and remove
the handle from the decorative glass.
f) Remove the two hex nuts from the
decorative label and remove the label.
g) Remove the decorative glass from the
frame.
4. To remove a hinge:
a) Remove the decorative glass and
handle from the door liner (see step 3).
b) Position the oven door liner with the
inner glass facing up.
c) Remove the two screws from the left or
right hinge you are servicing.
d) Lift the door liner and remove the hinge.
5. To remove the two pieces of outer oven
door glass:
b) Position the door liner with the outer
oven glass facing up, as shown.
c) Remove the two screws from the lower
bracket for the outer oven glass.
d) Slide the lower bracket off the first piece
of outer oven glass, then slide the glass
out of the top retainer tabs
e) Remove the three screws from the top
retainer and remove the retainer from
the liner.
6. To remove the inner oven door glass:
b) Remove the two hinges (see step 4).
c) Remove the first piece of outer door
glass (perform steps 5b through 5d).
d) Remove the two inner door liner screws
and lift the inner liner off the outer liner.
the liner
f) For the second piece of outer oven
glass, remove the two screws from the
left bracket, then remove the bracket
and second piece of glass from the
door liner.
e) Lift the inner oven door glass off the
outer liner
