AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Transformer replacement forKitchenaid Microwave KHMS155LSS4
I need help replacing the transformer in a kitchenaid microwave #KHMS155LSS4. How do I go installing it. Is there any dangerous parts I shouldn't touch
Don't touch the capacitor, it bites!! Nat
Most modern capacitors have an internal resistor that leaks off the high voltage, to be sure, just short it out temporarily. Lots of times the high voltage transformer will blow if the magnetron is shorted, just check.
i am replacing the thermostat # 8183697 on a kitchen aid khms147h i completed it as well as a new bulb light but still am getting no power to the control panel when i plug in i was told these were the parts needed i have not put the panel cover back yet would that prevent it from going on ?? thanks
Microwave Repair
