cjdog
#1 Posted : Thursday, November 20, 2008 3:50:18 PM(UTC)
cjdog
I'm prepared to buy replacement parts (right and left door hinges) and through talking with others, it was brought to my attention that an after market product was manufactured that has slightly smaller springs and holds up better. Unfortunately no specifics, so I figured I'd throw it out here in case someone has had similar problems. My oven door is "sprung". It will no longer shut properly. I need to replace the hinges. The hinges offered through APP.com are the exact same ones. These don't hold up.
libertyappl
#2 Posted : Thursday, November 20, 2008 4:21:25 PM(UTC)
libertyappl
Unfortunately, those are the only hinges that will work in your model. Your range was made by Frigidaire and there aren't any cross referencing parts for the hinges.
Nat
Viking Oven door opens only 1/2 in. Did not use self -clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 1:50:17 PM(UTC)
Oven door almost opens (Oven Repair (including Ranges and Cooktops))
by hasyed 3/30/2023 1:13:59 PM(UTC)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
Frigidaire GLGFS66.ABB Oven Door Sticks at Broil Stop Position (Oven Repair (including Ranges and Cooktops))
by gdaarob 3/28/2022 6:15:15 AM(UTC)
Jennaire JGS8860BDP oven door (Oven Repair (including Ranges and Cooktops))
Belarus df911 11/4/2021 9:38:06 AM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
Frigidaire oven door hinge not locking (Oven Repair (including Ranges and Cooktops))
by jacobrobbins219 3/16/2021 5:42:08 PM(UTC)
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Samsung - Oven Door Won't Close Tight (Oven Repair (including Ranges and Cooktops))
by Samich 4/26/2020 7:59:48 AM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 8/19/2019 10:57:44 AM(UTC)
Replace oven door assembly or outer tempered glass (Oven Repair (including Ranges and Cooktops))
by Jkaup 6/15/2019 8:29:47 AM(UTC)
Oven Door still will not close after hinge and seal replacement (Oven Repair (including Ranges and Cooktops))
by Ten13 3/18/2019 8:45:03 AM(UTC)
