7upedition
#1 Posted : Wednesday, December 8, 2010 3:43:02 AM(UTC)
7upedition
Hi all, new to the forums.
I have a Ge Microwave (shame on me, no model # with me right now) but the unit functions properly, with the exception that it does not heat food.
I suspect the magnetron is not working? When I measured the resistance between filament terminals i have 7ohms. I read it should be less that 1 ohm. The magentron is an LG 2M246 050GF.
Is this true? Is the magnetron bad? Are these known bad units?
The capacitor tested ok, and I don't suspect the transformer because eveything else functions.
Thanks in advance :)
nrowe46
#2 Posted : Wednesday, December 8, 2010 3:44:57 PM(UTC)
nrowe46
I have a Ge Microwave It is a GE WES13S84SM2SS
Serial TM922492Mbut the unit functions properly, with the exception that it does not heat food. Light lights timer counts down.
neogara
#3 Posted : Wednesday, December 22, 2010 8:01:06 PM(UTC)
neogara
...yes, you have a defective magnetron. It shouldn't read 7 Ohm between leads. Replace it. before you do that, check a h.v. diode also.Good luck!
nrowe46
#4 Posted : Thursday, December 23, 2010 5:21:34 AM(UTC)
nrowe46
Need a special screw driver to open it up. Does anyone know what it is called? Seems to be a central point with a star around it.
neogara
#5 Posted : Thursday, December 23, 2010 10:57:27 AM(UTC)
neogara
...I am not sure how it calls, but I call it a "star" srew driver tip. Manufactures LOVE to do that. A reason, so less handy man get into a microware repair business, or do it yourself projects.
jjpeters1100@yahoo.com
#6 Posted : Tuesday, January 25, 2011 2:39:53 PM(UTC)
They are called tamper proof torx. Same as a regular torx but with a stud in the middle. You can purchase the correct tools at most tool stores.
