I have replaced the emitter board and control module and all that will happen is the ice maker will fill with water freexze the water but the harvest cycle will not start. Any suggestions?
Hi,
About the only thing left is to replace the ice maker. Often times you can remove the front of the ice maker and find the gear broken.
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi,
About the only thing left is to replace the ice maker. Often times you can remove the front of the ice maker and find the gear broken. no broken gear and will not jump with the T and h jumped with a wire?
