Debra Carlin
#1 Posted : 16 years ago
Debra Carlin
My husband replaced some lights and when he finished the garbage disposal and the dishwasher were not turning on. We reset the circuit breakers to no avail. I can't find any other reset buttons, does anyone have any ideas?? Thank you.
icehouse
#2 Posted : 16 years ago
icehouse
rattrapp
#3 Posted : 16 years ago
rattrapp
I'm guessing it's a bad circuit breaker. When you turned it off to do the lights it probably died and won't close again. If you replace that breaker (should be 15 amps) you'll likely fix the problem.
icehouse
#4 Posted : 16 years ago
icehouse
Let's not miss inform. :eek: Dishwasher, Garbage Disposal should be on separate 20 Amp Circuit Breakers and wired 12/3. This is by NEC.
Why changing lights would have an effect unless wired together which is not to code. :)
Possible dryer electrical problem (Dryer Repair)
by Dmillbhawk 12 years ago
Do I have electrical problem? Soap dispenser? (Dishwasher Repair)
by roger20 13 years ago
electrical problem (Oven Repair (including Ranges and Cooktops))
by robertwgeorge 13 years ago
electrical problem (Washer Repair)
by garycart 14 years ago
Electrical problem (Dishwasher Repair)
by capndavid2001 14 years ago
Maytag Dryer - first noise, now also electrical problem (Dryer Repair)
by RobBroekhuis 15 years ago
Electrical problem (Washer Repair)
by hb6306 15 years ago
Icemaker front panel electrical problem (Refrigerator & Freezer Repair)
by ttvor 16 years ago
Electrical problem (Refrigerator & Freezer Repair)
by mcbdallas 17 years ago
