When running on regular cycle the timer will buzz when it is finished but will not turn off and will start next cycle. Is this a simple part fix?
Looking for a little help out there.
SR
Sounds like the timer is messed up. I need to know what series of washer you have.
Nat
Admiral LNC6764A71 Serial # 12724911 REV 12??? That is what it says
It should be this timer then, part #AP246947 (This is series 10) AP3464380 (is series 21) Look at your timer and the pictures and you can tell which is correct.
Nat
